Hey All
My bike stutters when on low rpms in traffic.When opening the throttle she response normal at high rpms .When It first started I decided to do a service plugs oil petrol pump cleaned out and filtter changed I also had shims done
She ran ok for a few days then it started again
She would cut off while starting to warm up only idle for awhile.After riding the start up idling is ohk no misses I checked with wet finger if all four branches are getting warm they all do
Any suggestions to what the cause could be the jerking is not constant mostly when slowly opening the throttle at low rpms 4000 rpm and below
