1 - 10 of 10 Posts
Was wanting get a little advice on some up grades for my 06 zx10r, I already have: Full ak evo, powercommander, b&c race filter. What else is out there to get more power?
Thx!
Thx!
not much in terms of bolt-on goodies so its either internal or leave it as is.
:+1:
There's the ignition module to go along with the PC. You might get a couple hp from that. Other than that, like BD said, you'll have to get into the engine.
Some nitrous is always an option.
not sure what the 06 is stock gearing -1 in front +1 in the works on the 05 for me!! 3rd gear @ 90+ the front comes right up!!!
Supercharged Mod
Actually, unless your name is Nicky Hayden, the best upgrade path involves improving the nut behind the handlebars. Software, in particular. (Seriously!)
MIA Ex-Mod
I think from there your best option is upgrading the suspension would help put the extra ponies to the ground. I think it would in some ways be like adding more power simply by allowing it to be used more to its potential.
Also, have you had a custom map done for the mods you currently have? Have the suspension setup and/or upgrade the suspension. Oh, aftermarket wheels, lighter wheels, reducing the rotating mass always has a benefit on the performance. I think it would be like adding 10 hp to the 10r.
Tread
Map!
I ordered Ivan's TRE, and PC with its full system map. The wheels have to come last due to lake of money. I also ordered the Kawasaki race cam. Has anybody done this and if so what was the results?
1 - 10 of 10 Posts
