1 - 8 of 8 Posts
please help me im new here and i need the right side fairing bracket for my zx10 :dontknow: . the one that attaches to the motor mount. my buddy and i changed the valve cover gasket and it some how disappeared :dontknow: if anyone can help me with this it would be great.
thanks
Hillbillie Mod
I think that the right side bracket is just a bolt with a hole in it. Id have to look to be certain...but check all the engine mounting brackets to make sure you didn't replace a bolt that didn't have a hole it it with the one that did!
I do believe Mr. Hillcountry10r is correct. Thank you good sir, for all of your insight and knowledge.
no i checked all of the bolts top to bottom and i dont see any of that sort they all look like there in their place
Ahhhhhhhhhh the ever disappearing RH brkt, well as my two astute collegues have pointed out and confirmed there isn't one (technically).
Good show gents!
Hillbillie Mod
pumkinkiller said:
well i'll do some more searching and see what i can come up with
dont forget the ones that mount vertically! :wink:
Discussion Starter #8
:thumbsup: i found the bolt it was hidden on the bottom of the frame i switched them out and we're good to go now THANKS for all your help
1 - 8 of 8 Posts
