1 - 4 of 4 Posts
Whats up fellas wanted to ask if any body can help me on guiding me on how
to install Ivans TRE on a 05 10r i recently bought it from a member here but
he no longer has the instructions..if any body can post a pic where ir plugs
into or any help will be much appreciated
Licensed Dist of HaterAde
The white plug on the left side of the airbox (front left between the larger gray plugs and the hose)....nevermind the tube that's circled in the pic...that's for the block off plate alternative. there are only 2 white plugs like this and the other is at the back of the airbox and is used for the power commander.
Ivan's TRE should be installed on the green connector. (lower left below the fuel rails in TMY10ER's pics).
Remove the green w/red stripe and black wires from the green connectors, hook up the TRE. Doesn't matter which one is where. It's a bit PITA
1 - 4 of 4 Posts
