Of course you are faster
Guys who have done it, need some help.
I have a guy who has purchased an insert and is running into problems with the install :eyecrazy: can't get enough extra cable slack.
Let me know what you did to get enough slack, I've proposed cutting off the cable tentioner lock rings and trimming back some of the threaded cable housing.... this should allow you to turn them in even farther and get more cable slack....
that plus any help with how totally clean the two little metal tabs need to be in the housing.... I took them out with a milling machine so they are TOTALLY gone on the one housing i worked on.
Give me some input, don't want to leave this guy hangin'. He deserves your tips and help.
Hook us up
thanks
