1 - 6 of 6 Posts
I'm getting ready to swap out my brake reservoir and want to clear the lines out and put some fresh fluid in there. I have a couple of Motul RBF 600 DOT4 brake fluid containers that have been on the shelf for about 3 years. I know at least one has been opened. It's been sealed tight, do you guys think they are both alright to use?
Spray brake cleaner through the lines and blow them out with air. You may as well upgrade to steel braided if you have not done so.
1 - 6 of 6 Posts
