1 - 3 of 3 Posts
I installed aftermarket front turns(NOT LED).
Left side works perfectly, but the R don't.
I can get the R to work maybe every 7th
time I try, then they work fine. They continue
to blink until I hit the cancel button.
I replaced the signal relay with OEM, same!
Then went as far as doing the auto signal relay fix.
Same problem. The R turn-signal doesn't flash
but once every 7th try. Any suggestions guys??
Finally solved my problem. After replacing signal relay,
mounting an aftermarket signal relay, rechecking all 4
bulbs, and rechecking fuses, I bought a left-hand control
from Felix el gato. Included were the screws/wiring.
After plugging in like new control, signals worked
PERFECTLY!! If anyone needs a signal relay for at
the 04/05, I now own (3)............
1 - 3 of 3 Posts
