1 - 9 of 9 Posts
It turns over fine from the sound the fuel pump primes and turns on the exhaust baffle turns on but bike won’t run I changed the spark plugs and it didn’t fix it any help would be awesome thanks in advance
Did it sit all winter?
Starter or battery maybe? Hard to start sometimes if your battery isn't 100% or close to it. Even if it turns, just not turning fast enough.
formerly GHOST RIDER
I would start with the battery.. then go from there...
Hey man ive had to go thru everything on my gen 1 because it wont start I would look at all of the above for basics
battery
starter
check coils
starter solenoid
ignition switch
clutch safety
kickstand safety
gear sensor
cam sensor
tip over sensor
mine was a starter solenoid, kickstand, and tip over
I could also be your stator I had a FAR 600 that wouldn't start it would turn on and turn over and it would even idle if I had the jumper cables hooked up to my car but as soon. As I turned the throttle or in hooked the cables it would die turned out it was the stator. Your stator is the source of spark for the bike it also works with the timing
1 - 9 of 9 Posts
