1 - 3 of 3 Posts
Recently switched the loom on my 04 to get rid of faulty datatool alarm, and somewhen between doing that and putting all the fairing back on the headlight & indicators have stopped working. Have checked for any loose connections but can't seem to find anything. I'm sure it's just something simple but can anyone point me in the right direction? Thanks
There are 2 connectors in the left upper fairing, they are bolted on a hook with a screw. Are these connected? I remember for one of them, you must unplug the iron hooked connector, connect it with it's other half and rehook it complete, otherwise it will not work.
I did connect those blocks using the process you described. The headlight was defo working initially but seemed to stop after I put the fairing all back on. Cheers anyway man
1 - 3 of 3 Posts
