1 - 19 of 19 Posts
inappropriate
:dontknow: i bought a used pc3 from a fellow member. when i tested the pc3 w the 9 volt it had no prob powering up and linking to my laptop were i could retrieve its current map. however, once plugged into the 10s harness it will not power up (flash its little lights) independently. worst yet when i would start the bike it would turn over then immediately cut the motor. the "FI" light is also illuminated during this time. i could twist the throttle to give it gas but that would only result in a mess of smoke and rough operation. when i removed the pc3 and reconnected everything as it was the bike will operate fine.
i removed the unit, inspected all pins and wires and reinstalled. no luck yet, same symptoms as my first attempt. :eyecrazy:
unhoook everythign and put it back to stock and see if you bike starts and runs fine than...it may have been damaged in shipping :dontknow:
inappropriate
i was afraid of that. isnt there a way to reset it?
silly little thing, on the pc3... on plug goes right into the fuel rail, and the 2nd plug gets the connection to the old plug that was going to your fuel rail, i think its brown.
i know i was a retard. and did it wrong.. i plugged one forgot to plug the other and had the same FI light issue.
inappropriate
can you clearfy? i cant quite make out what your saying.
Make sure you have the pc hooked up correctly:wink: is what he is saying. If the connectors are switched around or not plugged in correct this could be the result you are seeing.
inappropriate
Discussion Starter #8
inappropriate
Discussion Starter #10
this is the two connectors i was working with.
what i was saying is that there are 2 connectors... one connector goes right into the fuel rail where the OEM connector was, and the OEM connector gets plugged into the second pc3 connection.
easy to tell... one is a male connector one is a female connector. both need connection for proper function otherwise it will do exactly what you are saying is happening.
that's the wrong one.. you want the white one there, and the BROWN one that's under the other side of the fuel rail (right side) - it's buried deep but you can get to it
inappropriate
Discussion Starter #13
ohh no shit!? im going to check again and remove the black cover plate.
Make sure it's grounded good, because my friend had similar problem on his ZX-14....And it was the freaking ground wire that needed grounding better than how he had it.....
:+1::eek:ccasion1
inappropriate
Discussion Starter #17
YOU GUYS ROCK!!! it works.
inappropriate
Discussion Starter #18
That's why we're here man:eek:ccasion1. BTW nice pic:spit:.
1 - 19 of 19 Posts
