1 - 7 of 7 Posts
easy, sounds like a short,
1st thing I would do is hook up a volt meter to the two pins of the fuse thats blowin and start unplugging stuff that is connected to the circuit, see when the voltage drops and trace it from there, if it doesnt drop then, its most likely before the circuit's first locate plug, like a wire screwed in to the frame. If the wiring system does not branch off (separated by connectors) unplug components. Sometimes components can be shorted out for whatever reasons.
Trace power wires first as usually they are usually the majority of issues when checking wirings.
So, start out by unplugging anything ignition related. If you have a wiring diagram, this would help out a ton. Any service manuals?
· Shorty's Performance
Discussion Starter · #5 ·
Thank you man Rep sent!! I will do all that monday morning and see what happens
No probs, let me know what happens, we'll see what else comes up :eek:ccasion1
one thing I forgot to mention is to see if there is actually voltage before and after key on/off (when does he blow the fuse, after key on, before on-like as soon as you stick in the fuse, then it pops with key out of ignition?) if it's off, then really start unplugging stuff. But if it's when it's on, then proceed as I stated in the beginning.
Pretty much sums it up. When painting my buddies gsxr750 one of his wires came down on the exhaust and did pretty much the same thing. When it's blowing fuses you can pretty much figure it you need to start there and work your way back down the wiring.
1 - 7 of 7 Posts
