1 - 8 of 8 Posts
Hello, I have a 06 zx10r and I am looking to stretched my bike for track no more then 6" I looked into extensions, but what I would really like is a whole aftermarket swing arm. I did some searching but I am had no success in finding any companies that make extended swing arm for 2nd gen. zx10r can some please help me locate one? Thank you
Thank you kawikid511 is that the only one out there? it seams like there are a lot of swing arms available for the 1st gen. is it because the 1st gen. does not have the under tail exhaust? I wonder if the 1st gen. aftermarket swing arm will fit I no longer have the under tail exhaust on my bike.
Evil will make you an arm for your Gen 2. Hopefully BigCat10R will see this. His arm is pretty sweet. Other companies to look for are Adams, Hardcore and Macintosh
BigCat for Prez!
Been had just noticed!! Yea evil made mine and its set up so I can keep my dual exhausts. I left my laptop back home so if u want PM me ur number and ill txt u some pics of mine.
The other companies wanted $200 extra to allow the arm to run duals so i went with the evil for $700. U should order urs 4-8in since they come in 4in adjustment increments, but im 8-12 and im currently at 10in over
Hello, I just bought a Trac dynamics +6 swingarm here locally on craigslist this is a brand new swingarm has a built in air tank comes with bearings and axle the seller said it's for the 04-05 zx10r I laid the swingarm right next to my 06 it looks like it's going to bolt right on. I never heard of this company hopefully everything is going to be fine.
BigCat for Prez!
With a 1st Gen arm ull have to swap to a side mount exhaust bec it doesn't have the bend in it to make room for the Y pipe the 2nd gens have. What kind of metal is it made out of. U want it to be 4043 chromoly steel
Discussion Starter #8
Bike came with a roaring toyz side exit exhaust there is plenty of space for the swing arm. It's made out of aluminum it does have the under bracing it looks tough
1 - 8 of 8 Posts
