Hey guys :hello: - I have a small problem with the lambda sensor on my 2006 10r.
Bike started displaying error 67 - damaged sensor heaters, wiring open or short. I changed the sensor which appeared faulty, turned the ignition on - no error. Started it, no error. Put the bike back together, took it out for a test and, after a few meters, light started flashing again :surprise:. Stopped, restarted engine and light was not there again. It appears that it is not recognising a mistake until you drive off. Any ideas?
Or should I just get this http://www.ebay.co.uk/…/Oxygen-lambda-o2-sens…/251641737545… - in which case, how can I ensure that the wiring stays OPEN so it doesn't take away from the bike's performance? And are there any drawbacks of using an eliminator? Do I need to do some additional setting up after fitting one to ensure optimum fuel usage and performance?
Also, I am a newbie to dealing with things like this, so would appreciate as detailed explanation as possible :grin2:
Thanks in advance.
Thanks in advance.
