1 - 2 of 2 Posts
I'm looking for the following measurements:
Distance between the inner front brake rotor faces/disc mount faces.
Gen4 ZX10R OEM wheels:
Gen5 ZX10R OEM wheels:
On The ZX10RR the distance is 142.6mm
I theorize that the diff between gen 4 and 5 is 10mm. Lets see what the data shows.
I am also postulating that the zx10rr marchesini wheel is the same with as the Gen4, and the ZX10rr brake discs are dished to bridge the difference. If that is the case, a simple solution for using gen4 wheels on a gen5 is to use zx10rr brake discs.
Help me prove or disprove my theory!
Thanks
D
Bump. Sorry I cant help with the data but I can bump the thread so that maybe someone who can will see it.
1 - 2 of 2 Posts
