1 - 20 of 36 Posts
I got a few dollars laying around from a recent eBay purchase (120$) I already have exhaust an f.Eliminator.
Im thinking.
Spools
Frame Sliders
HIDs
Windscreen
Any other suggestions?
-1 on front sprocket $40 (probably cheaper, depends on where you get it), Rifleman 1/5 throttle insert, SpeedoDRD from motomummy $70 (Personally don't have it but members here have some good reviews about it.)
Is it hard to get the chain adjusted back to where it's supposed to be after i put on the sprocket? I have a new '12 gen4 and on my service the shop adjusted it for me.
I meant eBay sale not purchase. :badteeth:
-1 sprocket, rifleman 1/5 throttle and ddm hid. Should be able to get all for $120.
Sent from my DROID2 using Motorcycle.com Free App
Discussion Starter #10
I like your selection.
I'm fairly new here and have seen a lot of posts about riflemans cable. What's the advantages of it?
Basically it gives you a shorter throw throttle. Quicker to wo throttle.
Boomer Sooner!
Technically it takes 1/5th of the turning required to go WOT away. Instead of it being a 90 degree turn it is now a 72 i believe. Just reading about the number though doesnt do it justice. If i had to take off every other mod done to my bike, and pick one, i would personally choose the 1/5th. I mean you get the most noticeable difference from it than almost any other mod i have done. Also it is only $25. I mean seriously, there is no mod that can even come close to what the 1/5th does, especially for that cheap.
The only bad side to doing it is you will never want to ride another bike without one again! I personally will never own another kawi that doesnt have this installed.
Discussion Starter #14
Thanks guys! Hopefully I don't have a hard time installing it. Never done anything with these type of clutch/throttle cables etc.
You're being directed on the right path!
Riflemans 1/5 throttle insert, -1 sprocket, maybe a radiator guard ($55), or levers maybe. Possibly a cool sweatband to put over the master cylinder reservoir :thumbsup: lol
From a "keep your plastics from being ground into dust if you go down" stand point I would do sliders, spools and fork protectors. Plus the spools are great for rear stand use.
BigCat for Prez!
Ive read from Skydoofus :lol: that the way frame sliders mount, if they hit hard enough will do damage to the motor
ZX-10R enthusiast
Yea, I'm not exactly sold on frame sliders. They are great if you only crash at low speeds or drop your bike.
I say windscreen and a 16T
Discussion Starter #19
I assume the factory is 17tooth then
It's not that difficult getting the chain adjusted, just make sure there is enough slack and not over tighten it.
1 - 20 of 36 Posts
