1 - 6 of 6 Posts
HI, GUYS,
I NEED A HAND, TO ADJUST THE SUSP TO MY WEITH...
WHT DO YOU THINK , IS THE BETTER CONFIGURATION TO MY WEITH, 95 KGs FOR MY ZX-10 07.....
THANKS FOR ALL ¡¡¡¡
what kind of riding are you doing ?
is 95 KG with all the gear ? ( track suit shoes, helmet etc )
I believe you will need to get stiffer spings (1.0 kg )
Ahh, No,
With All The Gear It Colud Be Around 100 Kg, And I Wat To Change De Susp. Setup To My Weith,,,
The Ride Is Sport Tourist,,,, Not For A Track----
Thanks ¡¡¡
You need stiffer springs, and about 35mm of travel on the front and about 30mm travel in the rear when you sit on the bike with gear for touring.
Banned
1st set you rider sag "forks" 35mm from full ex, "shock" 30mm from full ex ..you want 20 mm of free sag {no rider} in the front and 10mm in the rear....you may need to re-spring both.
1 - 6 of 6 Posts
