1 - 3 of 3 Posts
My Bike won't start can someone help.
So I have an 05, and I have been putting sruff on it since the day I got it. Well I went to go put a 40 shot of NOS on, and everything is installed. Then I went to put my TRE on the same day, and it went in fine. I got it all back together, started it up, let it warm up, and got on ready to ride. As soon as I sat on the bike it sputtered and died. So I thought it might be the TRE since the NOS is hooked up by itself other than running it through the HORN. So the next time I had time, I called IVAN about the TRE, and we went through some things, and I ended up taking it off thinking that might be the Problem. So it started up, and ran just fine. Well untill I took it off the stand to ride it. THen it died again. I scanned over the bike to see if anything wasn't hooked up and I didn't see anything. I have taken it apart four times now trying to figure it out. Its acting like its not getting fuel. Someone, anyone please help!!
Rent this space
Are you using a dry shot of nitrous or have you tapped into the fuel line?
Did it die when you put the stand up ? Check the stand switch if it did.
Did you plug the air sensor back in after you reinstalled the airbox.
Did you plug the fuel pump connector back together on the side of the frame ?
I'm using a dry system, and I know the air box sensor is plugged in, and so is the fuel pump. The fuel pump comes on and the secondarys open up like they are suppose to. I have checked everything, I checked everything I can think of including the kick stand switch now. The FI light keeps flashing, and I can't get any codes off the bike. I'm to stubborn to take it into a shop, it ran right before I ripped it apart.
1 - 3 of 3 Posts
