1 - 6 of 6 Posts
The instructions seemed simple enough. Bought it off a forum member and he couldn't remember the exact hookup. Took the bike apart and finally found out he didn't send me the connector with the red wire. Went back in to do it after I got it and it seems there are a bunch of extra wires, an extra connector and stuff out of place. Can someone point me in the right direction?
Instructions:
Discussion Starter #2
The GIpro harness and wires:
The connector I received had the red wire only, so I connected the green/red and black into it as instructed.
Third picture is everything I'm looking at.
Seems it should be simple as taking two wires from the factory harness and plugging them in the GIpro's. Maybe I'm missing something. Help appreciated. Thanks!
its because you need u remove some pin from the stock connector to plug it in the gi connector... i used the instruction that you have and it took me less than 10 minute and im not a mechanic..
After reading the instructions over I realized I was overlooking the male connectors in the plug under the F.I. rail I didn't pull out :headshake
But Thanks for the Great Support!
Pics installed, Available If someone is interested.
1 - 6 of 6 Posts
