1 - 2 of 2 Posts
I have been reading but cant find the answer anywhere...
Are there clear instructions with the shogun sliders for an 06/07??
THe torque specs confuse me. The center engine bolt is like 85 pounds of torque but the nut on the other side is only 33... Is the bolt threaded by the head? And it is reverse threaded?
I am getting the sliders tomorrow and wanted to get this all figured out so when I got home from work I could install them
Any insight or confirmation of them coming with clear instructions would be appreciated.
Thx!
I had the same problem. Yes they are threaded in reverse. I did not use a torque wrench as they are threaded in reverse with a lock nut. just tightened snugly. also, there is an additional bolt that needs to be removed so it will hold. hope this helps.
1 - 2 of 2 Posts
