1 - 5 of 5 Posts
Hi
I just replaced the spark plugs in my 2005 ZX10R...shit what a work..I was forced to remove upper engine brackets..- Now I am installing those back but on the right hand side there seems to be a slight problem..se my photo..the 2 upper bolts has been tighted already but there is a slight (5mm) clearane between bracket and frame (red arrow)...should I tight the bolt all the way so that the bracket bends and takes contact to the frame...see the red arrow (there is the problem)
Still here
bump- sorry no answer here.
Sounds kind of like the bolt put threads in the bracket though.
I installed all the bolts about half way by hand and just tightened them each a little bit at a time. When I removed the upper right bolt to install my frame sliders I noticed the motor fell away a little bit, so I loosened all the bolts and retightened all of them as if I was torqueing head bolts. And during my last plug change I just went ahead and tightened them all up the same way as before.
Yamaha service
Yamaha service said today that the lower bolt must be tighten to the moment first and after that the other ones...let's see...
1 - 5 of 5 Posts
