1 - 6 of 6 Posts
My water pump is leaking, dripping coolant fluid does it harm the bike otherwise to ride it ? cause i have a ride planned for tommmarow?
It depends where and how much it is leaking from. If it is just dripping a tiny bit from a the gasket or something it should be ok, but if it get worse and your coolant level drops there is going to be problems.
Licensed Dist of HaterAde
Plus if it gets on the rear tire you will have some really bad handling issues.
Ahhhhhhhhhhh YES!!!!! definately something to consider before the ride tomm!
1 - 6 of 6 Posts
