Hi, has anyone ever put heat wrap on a titanium race pipe (akrapovic) & if so did it affect the exhaust valves. I have heard it can burn the valve seat's but don't know if this is true
The ole "brittle" argument. Commonly used against BST wheels and not true there either.I don't know about burning the valves, but I do know it will make the titanium brittle over time from trapping the heat in. Believe me when I say that exhaust wrap is a fad with no top race teams using them. I've seen it done on some Ducatis but more to avoid burning your leg than anything.
Hotter = less dense. As exhaust gas cools, it expands which slows the flow.Wrapping keeps heat of hot exhaust gas, in the pipe(s), and that is a good thing to reduce heat to area outside the engine, getting back to the engine.
As far as performance on a naturally aspired engine... It ain't helping... Thingy is.. Hotter exhaust gas, is larger volume, and that is a tad harder to get out of the pipes.
Now if it is a turbo Charged engine, the larger volume and higher speed of the gas getting pushed out, increases the turbo speed, and that increases the boost.. So that is a good thing. :thumbsup:
