1 - 11 of 11 Posts
Gen2 Ripper
Just figured I'd share that HealTech electronics has an app that lets you quickly put in your gearing AND rear tire size to get a very quick correction factor. Plus the app gives you their programming step by steps. It also allows you to do a " indicated vs actual(via your GPS reading" correction factor. No more writing out their long division tables .
It's free and NO adds. I don't know how to link it so just go in your app store and type in " Healtech" and it will pop up.
Android only...
AWESOME!!!! thanks for the heads up! I just downloaded it. Gonna try it this weekend when I change my chain and sprockets!!!:thumbsup:
Gen2 Ripper
Thanks for linking it pearl. I like it. The rear tire size built in correction is nice. I run a 50 series rear tire and I was guessing what it threw me off. Now I know.
Nice find :)
did you ever solve the fi issue you had with your gen 3 ?
i am having the same problem now after installing healtech xtre
Gen2 Ripper
Discussion Starter #10
Not me man. I got a gen2 and NO Fi.
About an FI light Damon? I had it too on first install and found out it was just 2 cable that I swap out in a plug (I misread how the connector was presented on the instruction sheet). I would suggest to you double check all the cable and make sure they match what's on the instruction sheet.
1 - 11 of 11 Posts
