I've been through the better suspension threads, and have been able to sort a good portion of my issues out, but I'd like a bit of input.
08 10r, stock everything. Had some wallowing issues at speed though sweepers, and even slightly tighter corners. I wound up taking some of the pre-load out of the front and stiffening the rear up (compression) a bit. That seems to have addressed the wallowing issue for the most part. (I still get a swaying feeling through the sweepers, like the front is compressing and rebounding slowly), but not nearly as bad a previous.
What seems to have happened as a side effect is some pretty severe headshake over slightly rougher roads at speed. Last round got me fed up, as it was bad enough to get me thinking about the tank slapping me.
Ultimately I'm a bit unsure as to what the correct operations are to address these issues.
Sag was set, although I"m not 100% confident that it's near perfect, but should be close enough to move forward.
Any thoughts?
Any thoughts?
