1 - 7 of 7 Posts
Does anyone know if the headlights on a 06 zx10 are adjustable? I just installed a set of hid lights and the high beam seams to shoot at the sky.. I dind't know if it is able to be adjusted down in any way?
Yes. They are adjustable in both horizontal and vertical angles via adjustment screws on the back of the housing. I don't know what the degree of adjustability is though.
Does it adjust both sides at the same time or one side at a time? THE LOW BEAM IS PERFECT, THE HIGH BEAM IS JUST TOOO HIGH. THANKS FOR THE INFO
one at a time. You need to look and find the plastic knobs....
Right on, i'll have to give it a try tonight!
1 - 7 of 7 Posts
