1 - 8 of 8 Posts
I tried using header wrap, but the header is still burning through the fairing.
Does anyone know of any technics/materials that I can use to prevent the fairing from burning?
Thanks.
GEN II Driver
need more info. t/m/y bike and any mods. taking a stab in the dark from the comfort of my armchair: if you've added pipe/air filter without a tune/correct map you're bike will run lean/hot. not good for your fairing and not good for your motor. luck...
A description or pic of the effected area would help us help you.
I can't post any pictures as the fairing is now in a body shop getting painted.
However, thanks for all the help.
:+1:
Had the same problem with a Honda 1000RR once, sent it to get ceramic coated. That stopped the fairing from melting. Hope that helps
1 - 8 of 8 Posts
