1 - 6 of 6 Posts
How do you know if yours has gone bad? What are the symptoms?:dontknow:
FUCK!!! I goy none of that goin on but my bike still is runnin to frickin hot!!! Would a map that is to lean cause it to run hot?
Gen 5 Now!!
yes a map to lean would make it run hot. could be thermostat, could be temp switch, could be water pump. what temp is the bike running at?? in hot weather 215 degrees is not uncommom.
Guilty by association
how hot is it running? does it overheat immediately? Have you checked your air filter? it may be choking.
1 - 6 of 6 Posts
