1 - 20 of 22 Posts
What size head gasket should I use with the Race Kit Cam From Kawasaki? Thin Head Gasket .45, .55, and etc. Thanks Mike
i went with the .45mm gasket.. thats the thinnest one.. good luck..
What about the piston to valve clearance? Was it still good with the 45 head gasket? What Cam timing are you using to still be safe?
youll still have plenty of valve clearance with a .45..
I'd be surprised to see Deezuhl give up his cam timing. :cool:
Gunner said:
He probably would except IceMan won't give it up to him either:headshake :headshake
no sir.. its getting to be way to competitive to give away info like that.. maxton is going to be a MF to break records this year with the bikes i hear that are coming. well go up there and give it our best shot!!
Discussion Starter #10
Has anyone measured the head gasket from Muzzys to see whether or not it is the same height from kawi? Rumor has it that Muzzys is the same as the .55mm gasket from kawi. Can anyone help with this?
Banned
i called muzzys and they gave me their headgasket part number from kawi and it was the .55........ kawi makes a .50, .55 , and the stock one. im not sure its thickness..
Original tickness is 0.65mm
The 0.45mm is not available anymore from Kawasaki. You need to buy a cometic part#C86800-18 (0.038") thats about 0.457mm. The only thing is that it's like 70-75$.
I am waiting to see if Kawa will make it available a litle bit later in 2007 if not I will buy the cometic. The kawi price was 17$ when it was avalaible.
madkaw said:
Strap it to the dyno and dial the cams in whre you want them
sure if you want dyno HP.. if you want the bike to run as fast as possible you may want to factor in the ram air when you dial the cams. for that you need to get it wideband tuned on the road..
I purchased (2) 0.45mm head gaskets today from the dealership. $16.89 each.
I am curious what is the kawasaki part number you got.
Speed Freak
here are the kawi head gasket part #'s
11004-0022 Gasket-Head T=0.55
$16.92
11004-0023 Gasket-Head T=0.45
$16.92
11004-0026 Gasket-Head T=0.65
$72.58
11004-0034 Gasket-Head T=0.50
$16.92
11004-0052 Gasket-Head T=0.60
$16.92
Speed Freak
Megacycl cams and web cams have them but your looking at 800 + for a set from megacycle.
stick with kawi race.
1 - 20 of 22 Posts
