we have one in both are 10's, if your going to try and drive it back you will just have to set it where your stal is low. FYI isnt going to work good that way thoany one running the hays convertible clutch set up in there 10. looking for some input on running my 07 in slider mode. trying to work out how to set it up so i can still ride it back to the trailer after a run.
:thumbsup: we use 50cc scooters and it works great!!!thanks..looks like I'll be buying something to pull it back to the trailer with.may be one of them 150cc scooter's. I've seen a few of them with pipes and big bore kits that run all right for what they are...lol
if your going to ride the street just buy a MTC multi stage lock up!whats a good clutch for a 05 zx10 with heads and cams and a 50shot i do alot of street racing. and whats the difference between a lock up and convertible clutch
what do you all have your stall set at.we have one in both are 10's, if your going to try and drive it back you will just have to set it where your stal is low. FYI isnt going to work good that way tho
right around 4,000 I thinkwhat do you all have your stall set at.
