1 - 4 of 4 Posts
ordered some russell lines that work from an 06-10 zx10r but the factory banjo bolt isn't long enough to run through both banjos and into the M/C.
So obviously the stock lines go from one line then split into two at the triple tree which is why my bolt isn't long enough.
Where do I get a banjo long enough to fit the bill?
Thanks
A local motorcycle shop? A local brake shop? A local fluid power shop? :dontknow:
Personally, I would just order the right one...but I am guessing time is of the essence?
yeah I ended up getting a longer one from a local shop. You would think they would start adding a longer bolt to the kits but whatever.......
1 - 4 of 4 Posts
