Well a new thing....
The speedometer doesn't worked anymore.
Sooooo I checked connection between the speed sensor and the connection near the motor (near the valve cover on the left side of the motor).
Wires not cut connections good...
Sooo i checked the voltage who suppose to be betweenpositive and negative connection like the service code 24 at the 3.66 on the repair manual. The voltage who suppose to be there are 9 to 12 volts and I got 4.66 volts....What the hell.
So i change the speed sensor with one I know it work and same result.
The service code just don't appear on the Fi light (when you do the self diagnostic ..... nothing) Fi light just don't appear at all, nothing, nada, niet.
So now the next test are the one who implied the connetion who hook to the cpu (I'm going to do it) and where one of the pin give a certain voltage who's going to tell me if the cluste are bugged or cpu broken (I doubt because no cracks or anything appear pins are straight but who know).
But my main question are why there's no code appear on Fi light at all and no code appear when I do the self diagnostic ?
And for sure if anybody encounter this kind of problem and how they resolved it.
Sure it's happen to somebody else with a gen 1.
Oh yes I got a PC III on the bike and for sure no pins are screwed on it too and no difference happen when I plugged the cpu directly witout passing through the PCIII the speedometer doesn't show naything but 0 km/h (yes here it's in km/hr).
And yes no wires seem to be cut anywhere (that way I surely have a code....on the Fi)
So if there an electronic guru just communicate with me.
