I extended my 03 zx9 and need to get a rear brake line ..since im in the process of buying a new line i thought of replacing the front ones too with some green ones to match my color scheme..anyone know of a good brand to use or any light to shine on my quest
to answer your title question, yes a lot of members on here use aftermarket brake lines of the stainless steel braided variety.
Some good brands are Spiegler, Galfer, HEL. I personally have HEL on mine, front and rear. They will do whatever color line and banjo fitting, plus they can cut to whatever length you want as well. Heres a pic of my rear line. Fronts are exactly the same.
I believe you can contact HEL directly for them. I went through a seller on eBay that I also found their website for http://www.moto-heaven.com/store/HEL-Brake-Lines.html. They will pretty much cut you any length you want.
I'm using Venhill lines on mine front & rear and they have been great so far. Same deal as the HEL, you can get em on fleabay cheap cut to whatever length you want.
I have Speigler SS lines on mine. Check out the sponsors from this forum. I have bought stuff from Mary aka lexusrx and Mike aka ridersdiscount. Have nothing but great things to say about them! I'm sure the rest of the members here can vouch for that as well.
No, when we say cut them, the supplier that you are buying the part from will cut the length of the brake line and them fit the banjo to both ends of the lines for you. You just have to remove your old lines and install + bleed your new lines.
basically ya. or like I said, you can order on the site I posted earlier. Go for +6" and youll be good unless you plan on going even longer. Could get +9" and be setup for more of a stretch later on if you wanted to be.
Related Threads
Kawasaki ZX-10R Forum
2.1M posts
128.9K members
Since 2003
