1 - 4 of 4 Posts
well if so would like to know. i was told by Dynojet that the old shifters will not work on the pc5
Dynojet is right... PC III require a Normally Open sensor, while PC-V a Normally Close.
You can't get a PC-III to work with a PC-V,if you hook it up you will probably get a cut at the rpm's you set as a "minimum rpm threshold" for the shifter activation without pressing the lever...
Or you will press the lever to change the gear ( nothing happens) and when you release it you will then feel the cut...
Dynojet sucks... :thefinger
is that all it wants to see? so if i use a normally closed switch then i can get it to work?
1 - 4 of 4 Posts
