1 - 20 of 28 Posts
Here's a nice link i found that has a decent write-up with pictures for changing your tires using the harbor freight tire changer.
I usually just take them off and 10 bucks from a shop back home it was done, BUT since i moved i may have to start doing them myself. I know several of you guys use this, but i was wondering if i need to buy a compressor to get the bead seated? can you use just a tire pump?? or would a small portable tank be ok?
http://mcnamee.tzo.net/motorcycle/tools/hf_tire_changer/harbor_freight_tire_changer.html
good find :thumbsup: here's some rep.
Nice find! I"ve been thinking about buying one of these.
my friend has one we have been changing our own tires for couple years now works very good. also let the new tire set out in the sun for a little while to make it softer, to help the installation, whenever possible. yes you need a compressor to set the bead!!!
1rocket69 said:
Will a portable air tank similar to this work?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40057
And where do ya'll buy your new valve stems from? i don't have a bike shop close by
rocket...that tank won't work:headshake"....I have a 4hp 7 scfm @90psi compressor and sometimes that takes a few tricks to start the bead seal and then sometimes no problem. Not saying you need that but something just a little smaller at the min.
You can also take it to any car tire station and I bet most will fill the tire for free.
Rent this space
Can of brake cleaner and a match sets the bead just fine , I have done it when my compressor took a dump.
By the way I just ordered changer and motorcycle adapter from Harbor Freight and a balancer off E-bay total price: $200. No more paying for tire changes for me.
Discussion Starter #16
I was afraid it wouldn't work, guess i'll have to break down and buy a compressor. Don't want to be making a trip to the store just to finish the job.
Actually a 10 gallon air tank will seat the bead on your tires EASILY. I keep mine pumped up to about 100psi and I can usually do a front and rear tire with no problem. I also have the harbor freight changer. Spend $75 on it total and have problaly changed close to 75 tires over the last 4 years...I have it cemented in the ground in my back yard. Very important that it is mounted solid. I originally tried masonry anchors and the whole machine was rocking back and forth. IT will work you to death compared to a Coats 220 or the like but for the price I think it's a good deal :eek:ccasion1
When I was in the Army we used that method on a Scraper tire that we had first tried the Army way of packing bead with grease it worked but the grease we had packed shot little fire balls all over the place when we lit it off.
yeah...on a bicycle it works just fine:badteeth: also that is a Holding tank rocket was looking at and needs an air supply anyway to fill...like a compressor:idea: ..same thing most here are talking about. :heyyou:
So call :bs: if your saying your filling tires with the same thing. :headshake:..at least for a Motorcycle and not your leg bike.:wink:
1 - 20 of 28 Posts
