1 - 17 of 17 Posts
I took my bike to get de-restricted and tuned. We used woolich tuning software.
Baseline we did 3 runs and got 161hp, 163hp and 164hp with 84ft.lbs. on the 3rd run. The third run sent the bike into limp mode. We learned that it was because we didn't hook the ECU up and disable the front wheel speed sensor fault code before running it on the dyno.
The tuning shop had ordered a bench flashing harness so the ECU had to be removed from the bike to connect it to the computer. The diagnostic reset only works with the ECU in the bike. So we had to preform the stupid code reset procedure, 1. idle the bike for 30 sec or more, 2. take the bike out and ride it around at over 25mph for 5-10 min 3 shut it off and repeat 3 times. Riding the bike over 25mph for 5 minutes at a time is a lot harder than it sounds in Tucson. Did I mention it was 99° at noon that day?
Finally got the fault codes cleared and back on the dyno and we were able to start the tuning. Took the throttle valve restrictions out and ran it. It gained 5hp and the A/F reading was spiking lean at 10k rpms . So the tuner kept adding fuel until it started losing power but the lean spike at 10k was still there. Here is where it really exceeded my comprehension level. He said it was running so rich the dynos A/F reader was seeing it as lean ?. He pulled fuel and it started making power.
He got it up to 184hp 93 ft.lbs safely. Then we started talking about bumping the redline 500rpms. I told him I was pretty sure woolich had done it. We decided we trusted woolich. So we decided to send it and try 13,000rpms. I attached the video of the bikes first time revving to 13,000rpms. The bike made 209 hp 96ft.lbs. without changing the timing or fueling.
The tuner reached out to Anthony (WR NA) who reached out to woolich to see how aggressive they were running the timing on the H2 SX SE they tuned. After confirming that they had successfully been more aggressive with the timing we decided to get a little more aggressive. The bike made 216hp and 99ft.lbs. We then did 4 back to back runs. Runs 1 and 2 were 216hp then run 3 was 206 run 4 was 203. Since the bike was pulling power as it got hotter we decided to back the timing down a little to be safer.
My tune is a little on the aggressive side but the tuner and I both feel it is safe. My final setup resulted in 213hp and 97ft.lbs. after backing it down. So we added 49hp and 13ft.lbs. from a filter swap and tune.
The tuner even took the time to help me dial in my suspension which was awesome.
It is a totally different monster. I didn't really get a chance to push it because it was dark when I left. Night time along the 45 mile ride home means more drunks, animals and cops. But I did play with it as little. My first impressions of the bike when I first got it I thought the bike didn't really have the violent acceleration you'd expect. It was still fast but very refined and smooth. Now at lower rpms and throttle input the bike feels just as refined and smooth but it feels like there is less resistance working against it. Kind of like pushing a box across the ground vs pushing a box around that's sitting on a skateboard. But at full throttle holy cow it has some vicious acceleration. It's violent like the bike is trying to accelerate so fast the rider flys off of the back. I love it!
I did get a couple graphs, a base line vs final tune and the 216hp graph vs my old 174hp zx10r (air filter, 2/3rds exhaust, de-restricted, tuned) for comparison.
First time running it to 13,000rpms. I'm not going to lie I was pretty nervous.
https://youtu.be/B8-d9pvS0ps
Supercharger chirping on the dyno.
https://youtu.be/fRfDldK_x54
The bike on the dyno.
https://youtu.be/h3aCCEd-v4s
Baseline vs Final tune
Text Line Pattern Design Slope
H2 SX SE vs My ZX-10R
Text Line Parallel Design Font
The H2 & H2-SE gain about the same as any other bike with fueling and ignition tweaks, the difference with supercharged bikes is by increasing the RPM limit as this increases spindle speed = greater air charge.
While more RPM does = more peak boost, the H2 family is heavily neutered from the factory.... the % of gain from simply allowing the throttle to be all the way open from a 'flash tune' is far and away greater than any other bike in history. Once you figure out the small problem of lowering IAT's, the gains to be had from tuning become even more ridiculous; there is no comparing forced induction to any NA bike in this regard.
Another story that these WFO dyno pulls don't tell is how this bike feels at partial throttle... you know, when you're riding it around normally around town or on the surface roads... It is truly something to be experienced. :)
Discussion Starter · #9 ·
Gen 5s are getting 50hp from a tune and filter? Nice!
WTF? Gen 5's are not getting 50hp from a tune and filter, lol!!! I've never seen a Gen 5 dyno 220HP to the wheel.
Lun471k said that my results were "inline" with what guys are getting from a tune on their gen 5s. I was surprised and didn't really believe it that's why I put the question mark on my question.
Of course, thanks for clearing that up 0:). Now let me explain the reason I quoted you instead of him. You explicitly stated the 50hp, whereas he did not, and someone would have to go back and look at the dyno chart to see the peak BHP, and then already know what the stock GEN 5 BHP was and then do the math.
I wish these GEN5's were that tunable.
Discussion Starter · #11 ·
Of course, thanks for clearing that up <a href="http://Zx-10r.net/forum/images/ZX-10R_net_2015/smilies/tango_face_angel.png" border="0" alt="" title="Angel" >:)</a>. Now let me explain the reason I quoted you instead of him. You explicitly stated the 50hp, whereas he did not, and someone would have to go back and look at the dyno chart to see the peak BHP, and then already know what the stock GEN 5 BHP was and then do the math.
I posted my baseline run (with a new filter) and my final power as well as the graph with my best power I made with an overlay of my 2012 zx10r with full bolt one. I brought the bike in making 164hp at the wheel and left with the bike making 213hp to the wheel. That's a 49hp increase from just a tune. If someone says that another bikes results is "inline" with that I'd expect it to be in the ball park of 50 to make that claim. I asked the question giving him the benefit of doubt since I haven't been paying attention to the tuning of the 5th gens. Had he or someone else replied saying that people are getting a 50ish hp gain on the 5th gens i would have asked to see some dyno charts.
With all the restrictions bikes are coming out with 30+hp gains are possible from flashing and tuning the ecu.
You made how much? Uhm.. not on any dyno around me. 5th gens dont even come near that
Discussion Starter · #13 ·
Have you read the thread? I made a gain of 49 wheel horse power on my bike which is consistent with what others are getting with an H2 SX SE with a flash. I don't care if you believe it or not or what you think my bike would make on dynos near you. But out of curiosity where are you at? A 49 horse power gain is a lot.
Check the chart I posted. My bike has 200 crank horsepower from the factory. Factor in a 15% power loss along the drivetrain (200x.15=30 200(crankhp)-30(drivetrain loss)=approximately 170 wheel horsepower. Factor in the higher elevation and heat and 164whp baseline is pretty spot on. Ending the day with 213 wheel hp (made 216 whp but wanted a safer tune). 213-164=49hp gain.
Michigan
I have both a gen 4 and gen 5 and they dont make over 210rwhp
2016 Kawasaki ZX-10R KRT ABS Edition
Vcyclenut was able to get 218 out of these things.
Victors, you could probably get close to 210, at least 205 on E85 or MR12 with an intricate tune.
Nicks Performance Tuning in Florida, they're on IG too FYI, has some good work to show and a bit of info.
Discussion Starter · #16 ·
Michigan
So since your ZX-10R can't make over 210 horsepower an H2 SX SE wouldn't be able to is what your saying? If you were a lot closer I'd be interested in going to a dyno near you and showing you that you are wrong.
Sorry I caused so much confusion guys. I only meant that the bike was really gaining a lot from the tune. If you look at a Gen 5 ZX-10R, they easily unlock 30 hp from a decent tune. It might be from lack of experience, but I haven't seen at ton of "stock" bikes getting such efficient tunes (mainly because what chokes the engine are the new euro4 restrictions).
I just meant that proportionnally speaking, both the H2 SX and ZX-10R have tremendous tune/flash results.
1 - 17 of 17 Posts
