Hi all,
Short background here: used to own a '13, sold & took a few years off. Now about to buy a '16.
The '16 i'm looking at has a Guhl ECU flash. According to Guhl, the autoblipper can be enabled from the tach using the hand controls. I'm assuming that's possible because the sensor on the shift rod senses both push & pull, but the downshift direction is probably disabled from factory in order for Kawi to be able to sell the SE, RR trims, etc....
Does anyone know the procedure to enable the auto-blipper from the hand controls with a Guhl ECU flash?
