1 - 4 of 4 Posts
My bike after the last flash, idle whent crazy, like 3K after cold start, and then goes to normal, then goes to 3K... its not steady...
I tuned the EBC to off, and then idle goes to normal...
The strange thing is that that EBC map I have it from long time ago, so why is this happening now.
Also I developed a hunt like someone touches the shifter down, Im not touching it..
Any help is apreciated.
Discussion Starter #2
you can see in the data logs that TPS is 0% and ETV is 1.5%
used a new bin file for my ECU and copied and pasted all the tuned values... seams to work, regarding the shifter, used the sensitivity in 5, have to test it...
Anyone with experience moving the sensitivity.
thanks
The hi idle gone but blipper activating by itself continues
Sent from my SNE-LX3 using Tapatalk
1 - 4 of 4 Posts
