More power and less weight – it’s everything you need for Kawasaki’s 400cc machine.
You’ll save over five pounds of weight upon the installation of this exhaust, which, while it doesn’t sound like much, for these smaller bikes, weight savings of any kind are an especially welcome treat.
Starting with top-quality stainless steel headers that are precisely bent for a clean, trouble-free installation, the exhaust is topped off with an elegant Graves carbon fiber muffler. The whole system compliments the Ninja 400’s shape and style in addition to freeing up additional engine performance.
And performance is where it’s at – Graves claims that, once fuel delivery is properly adjusted, you can expect a 10% gain in engine output. Those kind of gains are unheard of with the simply addition of an exhaust and tune on any modern big bike that we can think of! The extra power will be appreciated when you open it up the first time out with your new exhaust.
For the truly performance-minded rider, an oxygen sensor bung is fitted as standard allowing maximum tuning possibilities with the appropriate hardware (TJ can tell you all about that!). It’s just another piece of this awesome exhaust the will help you get the most out of your Ninja 400.
Every exhaust comes with all required installation hardware and easy-to-follow instructions. If you’re comfortable with performing an oil change, then installing this exhaust will be no problem. An evening in the garage and simple hand tools are all it takes to get the job done.
To order yours, call TJ on 866.931.6644, send a PM here or email [email protected] and we’ll get back to you right away!
