1 - 14 of 14 Posts
First ride today with the damper, this thing does its job. I can go full throttle in first and get 0 shake. I have it set to 1.75 and I have a slight shake if I hit a dip in the road, but 2 made the setting feel stiff and unconnected.
I like the damper and it does its job. I can totally lock up the brakes and the rear no longer is able to begin to even feel like it wants to come around on me.
I will say that the Ohlins I used on the 636 did make the front end feel better (more solid and planted) than the GPR does on the 10r. I like the GPR but to do it over again I would have gotten an Ohlins...your opinion may vary. Although Ohlins does bind when going from lock to lock and it is very noticable. So U-turns suck.
thanks for the feedback.
I think the GPS should be considered by those on a budget as our bikes need a dampner.
I am VERY happy with my Scotts.
OG Post Whore
the scotts and gpr are like the same price
I got a Scotts for $250 off a bud, even though I didn't really want one. Now that it's on the bike I think I like it. I'm currently running it about 11-14 clicks out. Any stiffer than that and the steering starts to feel kind of dead. I did crank up the high speed circuit 1/2 turn from stock though. Nice unit, I just wish it fit a little better with the stock key :-(
Hillbillie Mod
I bet I have the most twitchy bike on the forum, and the GPR works for me...:badteeth:
Took my first ride with my GPR tonight and like you guys said worlds of difference from nothing at all. I like it.......... :)
It does its job straight up but leaned over the Ohlins is better IMO
maybe I should have said it like that from the beginning
There is no interference with the key. Turn the unit 180 degrees. The damper will still mount and work as designed.
Have never tried the scotts but I can find no complaints from the gpr damper. I leave mine on setting 4 and am very happy.
Discussion Starter #12
4 seems like it would be WAY too stiff for me
Hillbillie Mod
:+1: Me too.
BN, if 4 seem to stiff for you, I would say that is good, because it means your bike is pretty stable.....IMO anyway...
Discussion Starter #14
I got my stock stuff dialed in pretty well, I only got the damper for the head shake when hard on the gas and to give myself that little bit of extra confidence...2 was too stiff for me so I began dialing it back over a few runs on my 'test' road.
1 - 14 of 14 Posts
