1 - 18 of 18 Posts
I haven't had a chance to test it but I must say that I'm enormously disappointed that I needed to dremel the clamp mount to get it to fit over the steering stem. This didn't take more than 5 minutes but these things should be delivered in a working condition...however, my damper paddle thing fit in easily and didn't require much grease. I will get a chance to test ride this on the weekend to see what I think of its real world performance.
Hillbillie Mod
Could you be more specific. I put the same damper on with no problems.
the middle hole that goes over the steering stem
Hillbillie Mod
Well that stinks...did you call GPR and tell them the problem?
Perhaps you recieved the wrong model...A baseplate for a bike with a smaller steering stem?
OG Post Whore
i didnt have to cut or drill anything on my damper
makes me wonder if they made a mistake and not sent you one designed for the 10......cause mine took about 5 mins to install....everything fit perfect....you might want to give them a call just to let them know in case you have problems later on......you won't be disappointed in the performance and their customer service!
When researching the GPR sport riders test unit for the zx6r had the exact same problem...seemed all I needed to take off was the anodize and as soon as it got to shiny metal the thing started to go so I twisted it and rocked it into place with some wd40 to make her like a greased pig and push her into place.
Discussion Starter #10
slava said the delay in me getting it was for them to find another anodizer maybe it was put on too thick? Took me over 5 weeks to get it!
Hillbillie Mod
Discussion Starter #14
there is no torque spec for the bolts...the steering stem is 58ft lbs.
the instructions say do not over tighten..which means hand tight with loc-tite.
Discussion Starter #16
thread locker...liquid to make sure vibration doesn't loosen the bolt
Same as others have said - I installed mine about 4 months ago and have had several track days with it - fit perfect all of it. No problems I think ya got a bad one. Call em
Same here.
1 - 18 of 18 Posts
