1 - 2 of 2 Posts
Big shout to mdc160 for the awesome Bonamich reareset for my Gen 5. Question for the experts:
I have factory quickshift up and ecu programmed down, is it possible to just flip the knuckle to have gp quickshift up and down. Here is the blurb from Bonamichi:
Standard & Reversible "GP" Shift - adjustable shift linkage
(requires ECU to be reprogrammed (flashed) for use in "GP" Shift with Kawasaki OEM QS)
> For "GP Shift" install the Bonamici Shift Knuckle at 12 o'clock
> Insert the Bonamici Shift Rod (female / threaded side) into the QS
> Use only the OEM black color (no need to use the oem silver too) linkage
Thanks everyone for the guidance.
Sid
Premium Member
'16 ZX-10R KRT
Yes, you just flip the knuckle over for GP-shifting MECHANICALLY. After doing that, you must reprogram the ECU to reverse the direction that the switch uses.
As it says in the directions right here:
1 - 2 of 2 Posts
