1 - 5 of 5 Posts
A while back I put a Gipro on my 04 10R. The instruction recommend remapping, but say it isn't mandatory.
I only have a K&N filter and Yosh RS3 slip-on. The current map I have is for "stock or aftermarket filter w/slip-on".
Does anyone know where I can get a map for the Gipro with my set-up?
I am guessing it will make little differnce, but it's worth a try.
There is a post about this back n forth and then some. I remember reading about this and about the secondary all wrapped into one post...
It was under Performance or the How to section
I wouldnt worry about it. Not that big of a change.
Thanks for the info. I'll do some digital leg work...
Thanks for your thoughts. I am doubting it will be noticable, but if I can find a map, it is an easy test.
I am stationed in Germany, so I am for sure not gonna take it and have it dyno tuned with the sucky dollar-euro exchange rate. It would easily get into the hundred of dollars.
1 - 5 of 5 Posts
