1 - 8 of 8 Posts
Getting tuned here in a few. Wondering if the GiPro with TRE will affect the PC3 and Ignition Combo I have? Meaning since the TRE messes with timing is it going to effect the tunning of my PC3 and Ignition Module? I was just curious tho b/c if it effects it negatively then since I did not install it (GiPro w/ TRE) yet I will just sell it.
Thanks
I am pretty sure the gipro only tells it it is in 5th or 6th gear so the secondaries open up faster I don't think it has anything to do with ignition timing. If anything, it would advance the timing not retard it. It will affect your air/fuel ratio though for tuning.
bump pigeons :)
TRE's are used on many bikes when mapped or not. You will be fine...
Thanks every one :)
1 - 8 of 8 Posts
