1 - 15 of 15 Posts
Gettin Ready for Nov. the 2nd ...(UTI vs. MMI drags) ... Well this will be my first time at the track and I got a couple a questions about my setup and lookin for some Suggestions...
First I have a 06 with a BMC Race Filter and A&R Baffles. A dyno out here said that I Put down bout 164 to the ground with -1 Tooth in the rear.
I will be lowered 2 in" frt. and rear with a strap so the front end doesn't telescope at all. The only other thing is that I will have a Shinko 190 (soft) tire and I have no clue about what pressure I need to run. I have been thinkin bout a Kevlar clutch since I still rock the stock original w/ almost 18k miles on it. Do yall think the clutch will hold at what ever given RPM I should launch at?
Sry bout the long post I'm just bored at work and have nothing else to do!
Bolds are sorta some of the ?s that I have...
Yes Sir
inappropriate
just curious, why -1 rear?
Gas Mileage ... I average bout 44 mpg a tank from school and work...
Well i run 40 psi regularly out here in Phx ... got the shinko cause it was 120 and i need new rubber anyways
Beginner w/29k miles :o)
good luck Moto!
Discussion Starter #10
What yall think about my clutch .... Stock with 18k ... It doesn't slip now but after a couple of launches who knows ... Can get EBC Kevlar with stiffer springs for 90bucks ... so i might do that.
Shorty's Performance
Call Dwayne at cycle concepts! He will give you some good advise and he got pretty much everything in stock.
Good luck with that gearing ratio. I'm -1 up front and have a hard time getting out of the clutch launching from 5-6K. I get a lot of bog down if I don't stay in the clutch a bit. I feel like i need to go +2 in the rear on top of the -1 front to get it going. But 44mph is pretty sweet. Good luck man and be safe!
The Strip @ Las Vegas Motor Speedway !
Well I run 40 psi regularly out here in Phoenix AZ . . .
Got the shinko cause it was 120 and I need new rubber anyways.
We got a dragbike race November 8, 2008 at Speedworld in AZ.
You know that we will be in Vegas this weekend . . .
The Strip @ Las Vegas Motor Speedway.
Check www.LVMS.com for track info.
It's October 18, & 19, 2008 . . .
See www.MDRA4U.com
Team WandL Racing.
Red, *<:){)-
Discussion Starter #14
Yea I will be out at speedworld for sure on the 2nd!
1 - 15 of 15 Posts
