61 - 80 of 261 Posts
I just did the procedure!
My Engine is 17xxx and the rotor spacer is already 1.2.
I keep 0.6 very tight clearance on other side.
Unless the washers had a different material, And I understand that have, for me it is lost of time and money.
I dont know If was just dirt or If Really had Another material.
What did the parts for this repair cost? Did you buy all the parts listed in the bulletin? My 04's vin is 13 thousand somthing and I have 17,000 miles on mine and am thinking about doing this over the winter.
I spend about U$ 100,00 in parts...
I mentioned washers, but the correct is SPACERS.
If you read the PDF, the major reason to do this is because the change of material of the spacers... Anyway is done... but the best is buy a 05 generator, otherwise, hard to find :rolleyes:
Does anyone else that did this mod spend the same?....because i got to tell you $100 for spacers is not right or I don't believe it...the cover gaskets anyone that has worked on a 10R before knows how to recover gaskets. :wink: other than that not sure where the $100 dollars came from :dontknow:
Bloo
A full set of parts is about $65 + shipping at powersportsplus.com. I found no place that will offer a lower price.
Can you be more specific?.....what part # cost what got to say when I do my Winter oil change and do this mod I don't think it's going to cost me me $65 for washers......all though I do have extra and new Valve Cover and clutch cover gaskets i never used. :dontknow:
Bloo that's for the parts list as described in the bulletin:
1 Spacer 92026-0071 2 each $12.54
2 Washer(t1.2) 92200-0124 2 each $1.54
3 Washer(t1.4) 92200-0125 1 $1.54
4 Washer(t1.6) 92200-0126 1 $1.54
5 Washer(t1.8) 92200-0127 1 $1.54
6 Gasket, clutch cover 11061-0049 1 $12.88
7 Gasket, starter cover A 11061-0047 1 $6.90
8 Gasket, starter cover B 11061-0048 1 $4.45
9 Snap Ring 480J2400 2 each $3.39
Bloo
I just forget to say that my shipping cost is to Brazil :badteeth:
Any way... I bought all the list... Spacers, gaskets and washers...
Thanks for your response....I guess you didn't read what I responded too but no matter I can see by your post it can be done for under $16..edit my bad adding... sorry about under $30 with shipping or Tax dollars for some of us. :wink:....again thanks :eek:ccasion1
bloo
Bloo, the absolute minimun you WILL need are 2 spacers, 2 t1.2 washers and 2 snap rings. That adds to the sum of $34.94
edit* plus shipping!
:thumbsup:
Yep...sorry for being to frank I sent you and another Good Rep you guys rock but we are a site of the best Information on the ZX10R PERIOD none can compete so wanted to make sure we get ALL the INFO OUT THERE WHAT ARE THE CHOICES FOR PRICES. :wink::eek:ccasion1
Bloo
:thumbsup:
back to details how do others going to try this mod Know they don't need the other Spacers you pointed out? :dontknow: meaning the List you pointed out has others you never used them but I suspect that doesn't apply to all :dontknow:
Bloo
Bloo, once you have the generator assembled using the new spacers and the 1.2mm shims you need to check out the gap with a feeler gauge between the shim and the snap ring on the gear side to be between 0.6 and 0.9mm.
If the gap is outside this tolerance you will need to remove the snap ring again and change the 1.2mm washer for one of the others of the set which will bring the gap inside tolerance. Having said that you won't know if you really need other shim than the 1.2mm until you measure the gap. Just in case you need any of them better get them all otherwise you risk having the bike grounded for a few days until the new shim you need arrives.
Remember that a snap ring you remove goes to the trash bin. Always install a new one.
This whole proceduce is described in pages 14 and 15 of the bulletin.
I also applied graphite grease instead of oil between the washers and spacers...:wink:
Ok thanks I just went ahead and ordered all shim sizes:
Product Name Ordered Part# /
Replacement# Avail O F B C Carrier Tracking# Date Each Disc Total 480J2400 CIRCLIP 24MM480J2400ACT 2000 Estimated Ship DateNo ETA$3.39 $6.78 92026-0071 SPACER,24.3X38.0X2.092026-0071ACT 2000 Estimated Ship DateNo ETA$12.54 $25.08 92200-0124 WASHER,24.2X38X1.292200-0124ACT 1000 Estimated Ship DateNo ETA$1.54 $1.54 92200-0125 WASHER,24.2X38X1.492200-0125ACT 1000 Estimated Ship DateNo ETA$1.54 $1.54 92200-0126 WASHER,24.2X38X1.692200-0126ACT 1000 Estimated Ship DateNo ETA$1.54 $1.54 92200-0127 WASHER,24.2X38X1.892200-0127ACT 1000 Estimated Ship DateNo ETA$1.54 $1.54 Total Quantity 8 0 0 0 SubTotal $38.02 Shipping Fee $6.95 Grand Total $44.97
:thumbsup:
for me its a rattle noise, can hear it on short burst of the throttle in neutral
I have the same rattle in neutral when I rev it a little. I just went out and checked after reading over the entire thread and my engine number is 02XXXX which is after the 018111 production number eligible for the repair. Could I possibly have the same issue even if is it a "post-issue" number? Or am I looking for something else causing the noise?
