1 - 4 of 4 Posts
tried a search but didnt see anything to confirm... anyone happen to know? found a gen 4 adjustable for a good price wondering if it will fit my gen5
2016 Kawasaki ZX-10R KRT ABS Edition
The kickstand mounting bracket shape and leg are both different. I think the Gen5 may be a little longer as well. The mounting hole for the actual stand is technically the same though. The Gen4 uses a 10x30 half-threaded bolt and the Gen5 uses a 10x30 unthreaded bolt with an additional collar. In place of a nut they use a tiny cotter pin. In order to use the Gen4 stand on your Gen5 brkt you'll need to get a partially threaded M10 bolt and nut, that's all. Again, that bracket shape is different though... The Gen4 mount if flat and the Gen5 has a XX degree bend in it so there's no guarantee it's going to sit right.
Discussion Starter · #4 ·
thanks guys... saved me $35 ;)
they listed it as 2011-2016 but i had a feeling its a typo and they meant 2015, so i guess i was right, just a bad listing
asked if they carry a 2016 stand but no response yet
1 - 4 of 4 Posts
