Ill take some photos tonight, I have a Gen 5 tail on a Gen 4 but i bought the gen 5 subframe rear and undertray
Ill take some photos tonight, I have a Gen 5 tail on a Gen 4 but i bought the gen 5 subframe rear and undertrayAfter some help and advice on changing gen4 bodyit to gen5.
I have purchased a set of gen5 krt but they dont come with the undertray/ subframe or clock bracket.
Im wondering if anyone has any pics of these components so i know what im up against?
I think the undertray is now a 1 piece.
Also im hoping i can make custom brackets/ modify standard subframe to work.
Any advice would be great thanks as the parts are currently had to get hold of in the uk and i cant find pics on the net.
What tire is that? thxso if you are going to run track fairings all you need is the subframe rear (silver) and the new battery tray, if you get fairings that use a race seat that is. if you get fairings that dont use a race seat then you will need the front seat also.
Gen 4 subframe rear cant be used with gen 5 tail due to the way the new tail points up a lot further, the gen 4 subframe rear would stick out the fairings
Iv got a BSB subframe remover and battery tray that will work if you use a CRC full race seat style tail if you're interestedThats brilliant mate. Thanks for that info its priceless.
Looks like i better get a subframe from somewhere then.
I need to run all standard bodywork. Dont want race stuff.Iv got a BSB subframe remover and battery tray that will work if you use a CRC full race seat style tail if you're interested
lists all the stuff you will need for a street versionI need to run all standard bodywork. Dont want race stuff.
But i cant see what that plastic bit does. Just seems to bolt on top of subframe but as there is no ecu there isnt useless?lists all the stuff you will need for a street version
http://www.zx-10r.net/forum/f23/putting-gen-5-tail-gen-4-thread-p-312121.html
