1 - 4 of 4 Posts
Just wondering if aftermarket clipons like vortex and others have the little holes for the locating pins in the on/off and blinker high beam switch assemblys? Hopefully I'm explaining this correctly guys ... I tried a cheap set off eBay and they do not have the required holes I'm talking about so I would have had to drill them and or modify the switch assemblys! Anyways let me know what you guys think I'd appreciate it alot ! Plz ride safe y'all and have a wonderful holiday!
2016 Kawasaki ZX-10R KRT ABS Edition
They don’t. You gotta drill your own holes for all clip-on sets.
And the reason behind that is because a lot of aftermarket clip-ons are longer than OEM ones allowing you to not only pic your sweep and angle, but also your bar length. If you wanted your grips 1" outboard out you'd want your controls to follow suit, same goes for if you wanted them 1" inboard.
1 - 4 of 4 Posts
