1 - 3 of 3 Posts
Anybody know if you can install a gen1 clutch with judder plate in a gen4? I have a brandnew clutch for gen1 and the gen4 clutch is tossed. Ive seen where some posted the gen1 clutch is better and last longer in the newer gens, just curious if there swapable and better.
Sent from my SCH-I545 using Tapatalk
Yep, most of the drag gen 4 guys run the gen 1 clutch setup with the judder plate
Ok thanks for info. Are you still runing abs on your rear brake with the stretch arm if so how did you make the abs line longer?
1 - 3 of 3 Posts
