1 - 5 of 5 Posts
So I've got a 2012 ZX10 ABS and have bypassed the ABS unit but i'd like to actually remove it.
Does anyone know how this can be done? is it a case of non-abs wiring loom or wat is required?
If I can add this to my bike I would buy everything
Any know if you can add this ?
Kordo; You have to leave the ABS control unit plugged in, otherwise the bike will not rev over like 10,000 rpm, and you will have other problems. The only way you can remove the control unit is to replace the entire bike wiring harness with one from a non ABS model. Mike.
Discussion Starter · #4 ·
well i'm looking to race loom it and am planning on buying a new loom... so if the entire loom it changed for a non-abs model will it work? or will the dash/ecu throw codes
Shorty's Performance
I took everything off my 2013 zx14r and everything works perfectly fine, the engine works and performs perfectly fine.
1 - 5 of 5 Posts
